FAQ · 2008.08.30
CTB file format for printing (How to print as color or black/white ?)
Plot environment ;
- How to print as color or black/white ?
- How to print with pen width ?
CADian supports CTB file , 'color/width map' tab function , like AutoCAD.
How to use CTB file to define the Pen width at CADian ?
1. Execute PRINT(or, plot) command.
2.
3. Select "MonoChrome.ctb" at [Print Style Table(Pen ssignments) of the upper area.
(You can find that printing color is indicated as the black color)
Icad.ctb ------------ Print in color.
MonoChrome.ctb ------ Print in black & white.(Gray scale)
4. Select [Edit] button after select files
5. Select [Properties] tab
6. Select the color to change the pen width
7. Select line width at [Lineweight]
* If you don't find the width you want, pls register the new width value after select [Edit Lineweight] at the right end and buttom end
8. Please try after change all of them
