RE :It's still very slow when creating drawing in CADian 3D
I'm using CADian 3D and even after trying all the methods you suggested, it's still very slow when creating drawings.
I'm using an i7 computer, so it's not a slow computer either. I'm using the 3D version of CADian, but I'm wondering if there's a way to switch to a 2D version that loads without using the 3D version at all.
There is no function to turn off the use of 3D. I will attach a LISP file that can help speed up the process. Please enter the LISP program into the AP command under the 'bottom start' set, exit CADian, and then re-enter. Loading will be automatic. Once in CADian, enter command 'SUP' and then proceed to draw your diagrams. This should allow for a faster drawing environment.
