Paste the Block
There is a file with a block. When use CTRL + C and paste using CTRL + SHIFT + V in the same file, not ok. I tried to use Edit > Paste as Block too, but I can’t. * answer : It works normally, but it cannot be worked when the limits is set as 'on'. 'Limits=on' was the reason why it didn't work. So set the limits as 'off'. |
