CADian VBA Sample Code - 2 [ Set Paper Size ]
Private Sub CommandButton2_Click() Dim myDoc As IntelliCAD.Document Dim Limit_Points As points Dim Lower_Point As Point Dim Upper_Point As Point Set myDoc = ActiveDocument Set Limit_Points = Library.CreatePoints Set Lower_Point = Library.CreatePoint(0, 0, 0) Set Upper_Point = Library.CreatePoint(70000, 50000, 0) Limit_Points.Add Limit_Points(Limit_Points.Count).x = Lower_Point.x Limit_Points(Limit_Points.Count).y = Lower_Point.y Limit_Points(Limit_Points.Count).z = Lower_Point.z Limit_Points.Add Limit_Points(Limit_Points.Count).x = Upper_Point.x Limit_Points(Limit_Points.Count).y = Upper_Point.y Limit_Points(Limit_Points.Count).z = Upper_Point.z ThisDocument.Limits = Limit_Points End Sub |
