FAQ ยท 2013.12.11
CADian VBA Sample Code - 5 [ Circle ]
Creates a circle given a center point and radius.
Signature
RetVal = object.AddCircle(Center, Radius)
Object
ModelSpace Collection, PaperSpace Collection, Block
The objects this method applies to.
Center
The 3D WCS coordinates specifying the circle""s center.
Radius
Double; input-only
The radius of the circle. Must be a positive number.
RetVal
Circle object
The newly created Circle object.
Remarks
This circle is created on the XY plane of the WCS.
Dim icadDoc As IntelliCAD.Document
Dim icadCircle As IntelliCAD.Circle
Dim cenPt As IntelliCAD.Point
Set icadDoc = ActiveDocument
Set cenPt = Library.CreatePoint(1, 2)
""Add the circle to the .dwg
Set icadCircle = icadDoc.ModelSpace.AddCircle(cenPt, 4)
"" Display the entity
icadCircle.Update
MsgBox "Circle created w/ center point at 1,2."
