CADian VBA Sample Code - 8 [ MText ]
AddMtext methodCreates an Mtext (multi-line text) object and adds it to the drawing. Syntax objectVariable = object.AddMtext(InsertionPoint, Width, Text) Where: objectVariable is an Mtext object; object is one of the ModelSpace or PaperSpace collection objects or a Block object; InsertionPoint is a Point object representing the location to insert the text; Width is a double-precision variable or number representing the width of the bounding box; Text is a String representing the text to appear in the window. Examples... AddMtext method example ---------------------------------------------------------- ""objectVariable = Object.AddMText(InsertionPoint, width, Text) Dim icadDoc As IntelliCAD.Document Dim myText As String Dim mtextObj As IntelliCAD.MText Dim corner As IntelliCAD.Point Dim width As Double Set icadDoc = ActiveDocument Set corner = Library.CreatePoint(0, 9) width = 10 myText = "Test string for the AddMtext method" "" Add the mtext Object Set mtextObj = icadDoc.ModelSpace.AddMText(corner, width, myText) mtextObj.Update ThisDocument.ActiveViewport.ZoomExtents |
