FAQ ยท 2013.12.11
CADian VBA Sample Code - 10 [ Copy ]
Duplicates the given object to the same location.
Signature
RetVal = object.Copy
Object
All Drawing Objects
RetVal
Object
The newly created duplicate object.
Remarks
AttributeReference: You should not attempt to use this method on AttributeReference objects. AttributeReference objects inherit this method because they are one of the drawing objects, however, it is not feasible to perform this operation on an attribute reference.
NOTE You cannot execute this method while simultaneously iterating through a collection. An iteration will open the work space for a read-only operation, while this method attempts to perform a read-write operation. Complete any iteration before you call this method.
Dim myLine As IntelliCAD.Line
Dim myStartPt As IntelliCAD.Point
Dim myEndPt As IntelliCAD.Point
Set myDoc = Application.ActiveDocument
Set myStartPt = Library.CreatePoint(4, 4)
Set myEndPt = Library.CreatePoint(7, 3)
Set myLine = myDoc.ModelSpace.AddLine(myStartPt, myEndPt)
myLine.Update
"" Copy and rotate the line
Dim copymyLine As IntelliCAD.Line
Set copymyLine = myLine.Copy()
copymyLine.Rotate myStartPt, 10
MsgBox "Rotated the copied line 10 radians."
