CADian VBA Sample Code - 14 [ UCS #2 ]
Dim ucsObj As IntelliCAD.UserCoordSystem Dim originPt As Point Dim xAxisVector As Vector Dim yAxisVector As Vector Dim UCSName As String ""Set the origin and axes vectors. Set originPt = Library.CreatePoint(0, 0, 0) Set xAxisVector = Library.CreateVector(0, 0, 0, 1, 1, 0) Set yAxisVector = Library.CreateVector(0, 2, 0, 1, 1, 0) UCSName = InputBox("Type a name for the user coordinate system:") Set ucsObj = ThisDocument.UserCoordinateSystems.Add(originPt, xAxisVector, yAxisVector, UCSName) ""Specify the active UCS of the drawing. ThisDocument.ActiveUCS = ucsObj ""This specifies whether the UCS Icon is turned on. ""Set whether the UCS icon is turned on. ThisDocument.ActiveViewport.UCSIconOn = True ""This specifies whether the UCS Icon is displayed at Origin point. ThisDocument.ActiveViewport.UCSIconAtOrigin = True MsgBox "Origin coordinates: " & ucsObj.origin.x & ", " & ucsObj.origin.y & ", " & ucsObj.origin.z ""Get the UCS transformation matrix Dim TransMatrix As Matrix Set TransMatrix = ucsObj.GetUCSMatrix() MsgBox "First two values of matrix: "& TransMatrix.GetValue(0, 1) & " " & TransMatrix.GetValue(1, 2) |
