CADian VBA Sample Code - 15 [ Insert Image ]
CADian VBA Usage -15 [Insert Image ] Use only Bmp format file ... objectVariable = object.AddImage(ImageFile, [InsertionPoint, ScaleFactor, RotationAngle]) Dim insPoint As IntelliCAD.Point Dim scalefactor As Double Dim rotationAngle As Double Dim imageName As String Dim rasterObj As IntelliCAD.Image "" Select the image. imageName = "C:\Program Files\IntelliCAD2000\Samples\Dallas.bmp" Set insPoint = Library.CreatePoint(4, 2, 0) scalefactor = 1 rotationAngle = 0 "" Add the image in model space Set rasterObj = ThisDocument.ModelSpace.AddImage(imageName, insPoint, scalefactor, rotationAngle) rasterObj.ImageVisibility = True rasterObj.Update "" Determine properties of the image MsgBox "The image file is: " & rasterObj.ImageFile MsgBox "The image height is: " & rasterObj.ImageHeight & Chr(13) & "The image width is: " & rasterObj.ImageWidth MsgBox "The image visibility is: " & rasterObj.ImageVisibility |
