CADian VBA Sample Code - 21 [ Offset ]
object.Offset(Distance) object: Arc, Circle, Ellipse, Line, LightweightPolyline, Polyline, Spline, XLine Objects which this method to be applied. Distance: Double; input-only The distance to offset the object. The offset can be a positive or negative number, but it cannot equal zero. If the offset is negative, this is interpreted as being an offset to make a "smaller" curve (that is, for an arc it would offset to a radius that is "Distance less" than the starting curve""s radius). If "smaller" has no meaning, then it would offset in the direction of smaller X, Y, and Z WCS coordinates. Remarks For many curves, the result of this operation will be a single new curve (which may not be of the same type as the original curve). For example, offsetting an ellipse will result in a spline because the result does not fit the equation of an ellipse. In some cases it may be necessary for the offset result to be several curve "" Create the polyline Dim plineObj As IntelliCAD.LWPolyline Dim plineObj2 As IntelliCAD.LWPolyline Dim myPoints As IntelliCAD.points Dim pt As IntelliCAD.Point Me.Hide Set myPoints = Library.CreatePoints Set pt = Library.CreatePoint(1, 1, 0) myPoints.Add myPoints(myPoints.Count).x = pt.x myPoints(myPoints.Count).y = pt.y myPoints(myPoints.Count).z = pt.z Set pt = Library.CreatePoint(1, 2, 0) myPoints.Add myPoints(myPoints.Count).x = pt.x myPoints(myPoints.Count).y = pt.y myPoints(myPoints.Count).z = pt.z Set pt = Library.CreatePoint(2, 2, 0) myPoints.Add myPoints(myPoints.Count).x = pt.x myPoints(myPoints.Count).y = pt.y myPoints(myPoints.Count).z = pt.z Set pt = Library.CreatePoint(3, 2, 0) myPoints.Add myPoints(myPoints.Count).x = pt.x myPoints(myPoints.Count).y = pt.y myPoints(myPoints.Count).z = pt.z Set pt = Library.CreatePoint(4, 4, 0) myPoints.Add myPoints(myPoints.Count).x = pt.x myPoints(myPoints.Count).y = pt.y myPoints(myPoints.Count).z = pt.z Set pt = Library.CreatePoint(4, 1, 0) myPoints.Add myPoints(myPoints.Count).x = pt.x myPoints(myPoints.Count).y = pt.y myPoints(myPoints.Count).z = pt.z Set plineObj = IntelliCAD.ActiveDocument.ModelSpace.AddLightWeightPolyline(myPoints) plineObj.Closed = True plineObj.Update ""Offset the polyline Dim offsetObj As IntelliCAD.SelectionSet Set offsetObj = plineObj.Offset(1) offsetObj.Color = IntelliCAD.Colors.vicRed offsetObj.Update MsgBox "Offset completed.", , "Offset Example" Me.Show |
