ยท
2009.11.01
How to use VBA at CADian ?
Hello CADian Users, If you need to execute VB program at your system, you have to insatll VBA SET-UP program separately. If you do it, please downlaod the VBA.zip file And install it after release the zip file. Now please do these steps in order to use VBA 1. Execute ""Security"" command 2. Select ""low"" level 3. Exit CADian 4. Running CADian 5. Execute ""vba"" command ------------------------------------------------------------------- 6. Export each files alike FORM, MODULE and CLASS from environment of AutoCAD VBA 7. Import Exported files(FORM, MODULE, CLASS and more) from environment of CADian VBA Please edit some sentences according to CADian""s. You can refer to the sample code if you need ------------------------------------------------------------------- * CommonProjects.vbi from CADian plays a role like acad.dvb from AutoCAD. Helpdesk of CADian |
