FAQ ยท 2013.12.11
CADian VBA Sample Code - 2 [ Set Paper Size ]
Private Sub CommandButton2_Click()
Dim Limit_Points As points
Dim Lower_Point As Point
Dim Upper_Point As Point
Set myDoc = ActiveDocument
Set Limit_Points = Library.CreatePoints
Set Lower_Point = Library.CreatePoint(0, 0, 0)
Set Upper_Point = Library.CreatePoint(70000, 50000, 0)
Limit_Points.Add
Limit_Points(Limit_Points.Count).x = Lower_Point.x
Limit_Points(Limit_Points.Count).y = Lower_Point.y
Limit_Points(Limit_Points.Count).z = Lower_Point.z
Limit_Points.Add
Limit_Points(Limit_Points.Count).x = Upper_Point.x
Limit_Points(Limit_Points.Count).y = Upper_Point.y
Limit_Points(Limit_Points.Count).z = Upper_Point.z
ThisDocument.Limits = Limit_Points
End Sub
