FAQ ยท 2013.12.11
CADian VBA Sample Code - 3 [ ARC ]
Private Sub CommandButton1_Click()
- Draw an ARC using given centerpoint, Radius, Start angle, and End angle for ARC..
- objectVariable = object.AddArc(Center, Radius, StartAngle, EndAngle)
- * Center
- Variant(Double 3 element Array ); Input only
- 3D WCS coordinate for pointing the centerpoint of ARC.
- Radius
- Double ; Input only
- Radius of ARC.
- StartAngle , EndAngle
The start and end angles, in radians, defining the arc. A start angle greater than an end angle defines a counterclockwise arc.
Dim icadDoc As Document
Dim myArc As Arc
Dim cenPt As Point
Set icadDoc = ActiveDocument
Set cenPt = Library.CreatePoint(4, 2)
""Add the arc to the .dwg
Set myArc = icadDoc.ModelSpace.AddArc(cenPt, 3, 1, 3)
"" Display the entity
myArc.Update
MsgBox "Arc created w/ center point at 4,2."
End Sub
