ยท
2013.12.11
CADian VBA Sample Code - 5 [ Circle ]
Creates a circle given a center point and radius. Signature RetVal = object.AddCircle(Center, Radius) Object ModelSpace Collection, PaperSpace Collection, Block The objects this method applies to. Center Variant (three-element array of doubles); input-only The 3D WCS coordinates specifying the circle""s center. Radius Double; input-only The radius of the circle. Must be a positive number. RetVal Circle object The newly created Circle object. Remarks This circle is created on the XY plane of the WCS. --------------------------------------------------------------- Dim icadDoc As IntelliCAD.Document Dim icadCircle As IntelliCAD.Circle Dim cenPt As IntelliCAD.Point Set icadDoc = ActiveDocument Set cenPt = Library.CreatePoint(1, 2) ""Add the circle to the .dwg Set icadCircle = icadDoc.ModelSpace.AddCircle(cenPt, 4) "" Display the entity icadCircle.Update MsgBox "Circle created w/ center point at 1,2." ThisDocument.ActiveViewport.ZoomExtents |
