FAQ ยท 2013.12.11
CADian VBA Sample Code - 8 [ MText ]
AddMtext methodCreates an Mtext (multi-line text) object and adds it to the drawing.
Syntax
objectVariable = object.AddMtext(InsertionPoint, Width, Text)
Where:
objectVariable is an Mtext object;
object is one of the ModelSpace or PaperSpace collection objects or a Block object;
InsertionPoint is a Point object representing the location to insert the text;
Width is a double-precision variable or number representing the width of the bounding box;
Text is a String representing the text to appear in the window.
Examples...
AddMtext method example
""objectVariable = Object.AddMText(InsertionPoint, width, Text)
Dim icadDoc As IntelliCAD.Document
Dim myText As String
Dim mtextObj As IntelliCAD.MText
Dim corner As IntelliCAD.Point
Dim width As Double
Set icadDoc = ActiveDocument
Set corner = Library.CreatePoint(0, 9)
width = 10
myText = "Test string for the AddMtext method"
"" Add the mtext Object
Set mtextObj = icadDoc.ModelSpace.AddMText(corner, width, myText)
mtextObj.Update
