ยท
2013.12.11
CADian VBA Sample Code - 11 [ Rotate ]
Rotates an object around a base point. Signature object.Rotate BasePoint, RotationAngle Object All Drawing Objects, AttributeReference The object this method applies to. BasePoint Variant (three-element array of doubles); input-only The 3D WCS coordinates specifying the point through which the axis of rotation is defined as parallel to the Z axis of the UCS. RotationAngle Double; input-only The angle in radians to rotate the object. This angle determines how far an object rotates around the base point relative to its current location. ""********************************************** ""* Example 1 "" Create the line Dim myDoc As IntelliCAD.Document Dim myLine As IntelliCAD.Line Dim myStartPt As IntelliCAD.Point Dim myEndPt As IntelliCAD.Point Set myDoc = Application.ActiveDocument Set myStartPt = Library.CreatePoint(4, 4) Set myEndPt = Library.CreatePoint(7, 3) Set myLine = myDoc.ModelSpace.AddLine(myStartPt, myEndPt) myLine.Update "" Copy and rotate the line Dim copymyLine As IntelliCAD.Line Set copymyLine = myLine.Copy() copymyLine.Rotate myStartPt, 10 MsgBox "Rotated the copied line 10 radians." ThisDocument.ActiveViewport.ZoomExtents ""********************************************** ""* Example 2 Dim icadDoc As IntelliCAD.Document Dim myText As String Dim textObj As IntelliCAD.Text Dim insPt As IntelliCAD.Point Dim height As Double Dim NewRotation As Double Set icadDoc = ActiveDocument Set insPt = Library.CreatePoint(0, 9) height = 5 myText = "Test string for the AddText method" "" Add the Text object Set textObj = icadDoc.ModelSpace.AddText(myText, insPt, height) textObj.Update ThisDocument.ActiveViewport.ZoomExtents MsgBox "Rotation: " & textObj.Rotation NewRotation = InputBox("Type a rotation (in radians):") textObj.Rotation = NewRotation textObj.Update ThisDocument.ActiveViewport.ZoomExtents |
