FAQ ยท 2013.12.11
CADian VBA Sample Code - 11 [ Rotate ]
Rotates an object around a base point.
Signature
object.Rotate BasePoint, RotationAngle
Object
All Drawing Objects, AttributeReference
The object this method applies to.
BasePoint
The 3D WCS coordinates specifying the point through which the axis of rotation is defined as parallel to the Z axis of the UCS.
RotationAngle
Double; input-only
The angle in radians to rotate the object. This angle determines how far an object rotates around the base point relative to its current location.
""* Example 1
"" Create the line
Dim myLine As IntelliCAD.Line
Dim myStartPt As IntelliCAD.Point
Dim myEndPt As IntelliCAD.Point
Set myDoc = Application.ActiveDocument
Set myStartPt = Library.CreatePoint(4, 4)
Set myEndPt = Library.CreatePoint(7, 3)
Set myLine = myDoc.ModelSpace.AddLine(myStartPt, myEndPt)
myLine.Update
"" Copy and rotate the line
Dim copymyLine As IntelliCAD.Line
Set copymyLine = myLine.Copy()
copymyLine.Rotate myStartPt, 10
MsgBox "Rotated the copied line 10 radians."
""* Example 2
Dim icadDoc As IntelliCAD.Document
Dim myText As String
Dim textObj As IntelliCAD.Text
Dim insPt As IntelliCAD.Point
Dim height As Double
Dim NewRotation As Double
Set icadDoc = ActiveDocument
Set insPt = Library.CreatePoint(0, 9)
height = 5
myText = "Test string for the AddText method"
"" Add the Text object
Set textObj = icadDoc.ModelSpace.AddText(myText, insPt, height)
textObj.Update
MsgBox "Rotation: " & textObj.Rotation
NewRotation = InputBox("Type a rotation (in radians):")
textObj.Rotation = NewRotation
textObj.Update
