FAQ ยท 2013.12.11
CADian VBA Sample Code - 14 [ UCS #2 ]
Dim ucsObj As IntelliCAD.UserCoordSystem
Dim originPt As Point
Dim xAxisVector As Vector
Dim yAxisVector As Vector
Dim UCSName As String
""Set the origin and axes vectors.
Set originPt = Library.CreatePoint(0, 0, 0)
Set xAxisVector = Library.CreateVector(0, 0, 0, 1, 1, 0)
Set yAxisVector = Library.CreateVector(0, 2, 0, 1, 1, 0)
UCSName = InputBox("Type a name for the user coordinate system:")
Set ucsObj = ThisDocument.UserCoordinateSystems.Add(originPt, xAxisVector, yAxisVector, UCSName)
""Specify the active UCS of the drawing.
ThisDocument.ActiveUCS = ucsObj
""This specifies whether the UCS Icon is turned on.
""Set whether the UCS icon is turned on.
ThisDocument.ActiveViewport.UCSIconOn = True
""This specifies whether the UCS Icon is displayed at Origin point.
ThisDocument.ActiveViewport.UCSIconAtOrigin = True
MsgBox "Origin coordinates: " & ucsObj.origin.x & ", " & ucsObj.origin.y & ", " & ucsObj.origin.z
""Get the UCS transformation matrix
Dim TransMatrix As Matrix
Set TransMatrix = ucsObj.GetUCSMatrix()
MsgBox "First two values of matrix: "& TransMatrix.GetValue(0, 1) & " " & TransMatrix.GetValue(1, 2)
