FAQ ยท 2013.12.11
CADian VBA Sample Code - 15 [ Insert Image ]
CADian VBA Usage -15 [Insert Image ]
Use only Bmp format file ...
objectVariable = object.AddImage(ImageFile, [InsertionPoint, ScaleFactor, RotationAngle])
Dim insPoint As IntelliCAD.Point
Dim scalefactor As Double
Dim rotationAngle As Double
Dim imageName As String
Dim rasterObj As IntelliCAD.Image
"" Select the image.
imageName = "C:\Program Files\IntelliCAD2000\Samples\Dallas.bmp"
Set insPoint = Library.CreatePoint(4, 2, 0)
scalefactor = 1
rotationAngle = 0
"" Add the image in model space
Set rasterObj = ThisDocument.ModelSpace.AddImage(imageName, insPoint, scalefactor, rotationAngle)
rasterObj.ImageVisibility = True
rasterObj.Update
"" Determine properties of the image
MsgBox "The image file is: " & rasterObj.ImageFile
MsgBox "The image height is: " & rasterObj.ImageHeight & Chr(13) & "The image width is: " & rasterObj.ImageWidth
MsgBox "The image visibility is: " & rasterObj.ImageVisibility
