ยท
2013.12.11
CADian VBA Sample Code - 24 [ SaveAs]
Save the documents or Menu Groups as specified file. Object.SaveAs FileName, FileType ""FileName : String; Input-Only ""Total Path and name for file ""New name will be used for active documents or Menu Group. ""FileType : Type to be saved ""vicVersionR13 ""vicVersionR14 ""vicVersionR2000 ""Drawing can be saved only as DWG format. ""To save the document as another format, use Export method. Application.ActiveDocument.SaveAs "C:\testing", vicVersionR2000 |
