Utility Archive · 2026.02.13
[Lisp #48] BAROB : Quick Block (Timestamp)
  • BAROB
This tool instantly creates a Block from selected objects, automatically naming it with the current date and time.
  • Smart Naming : Instead of generic or confusing names (like standard "Quick Block" features might assign), this tool names the block in the format BL + Current Date/Time.
  • Speed : Streamlines the block creation process by removing the need to manually type a name.
  1. Type BAROB in the command line and press Enter.
  2. Select the Objects you want to convert into a block and press Enter.
  3. Specify the Insertion Base Point for the block.
  4. The objects are converted into a block named BL followed by the timestamp (e.g., BL20240828...).
