Utility Archive · 2026.02.27
[Lisp #197] SCUT : Draw Internal Cut
  • SCUT
This tool automates the process of cutting or grooving the inner section of a shaft.
  • Version Compatibility: It works on all versions of CADian. It automatically detects the version and adjusts the internal trim routines accordingly.
  • Functionality: It simplifies creating internal cuts/grooves by defining reference points and dimensions (width and height of the cut).
  1. Type scut in the command line and press Enter.
  2. Select Point 1 (Reference point on the shaft).
  3. Select Point 2 (Another reference point).
  4. Select Point 3 (Position for the cut).
  5. Enter the Horizontal Length (Width) of the cut to be made.
  6. Enter the Vertical Height (Depth/Height) of the cut.
  7. The shaft inner section is modified according to the inputs.
