Utility Archive · 2026.02.27
[Lisp #210] LP : Draw L-Plate Views
  • LP
This tool automatically draws an L-shaped bent plate, including the side view, based on user-defined dimensions.
  • Automation: Automatically creates the plate geometry with options to include holes and centerlines.
  • Inputs: Requires specifying material thickness, bend radius, lengths, and hole configurations.
  1. Type lp in the command line and press Enter.
  2. Click the Start Point (Bottom-Left corner).
  3. Click a point for Horizontal Direction, then a point for Vertical Direction (forming a 90-degree angle).
  4. Enter the Material Thickness.
  5. Enter the Bend Radius (bottom-left corner).
  6. Enter the Total Horizontal Length and Total Vertical Length.
  7. Draw Centerlines? (Type Y for yes, N for no).
  8. (If Y) Enter Centerline Distances and Hole Diameters as prompted.
