Utility Archive · 2026.02.11
CADian Lisps Download & Install Guide
Here’s how you can install these Lisp programs :
For CADian Pro 2025 & 2026 Users :
1/ Exit any running CADian program
2/ Download the attached file :
  • CADian 2026 : CADianLisp_Pro2026_Installer.zip
  • CADian 2025 : CADianLisp_Pro2025_Installer.zip
3/ Extract the downloaded file
4/ Run the installer file : CADian Utility - Installer.exe
5/ Once the installation is complete, launch CADian
6/ Utility programs will load automatically, adding a new menu to your interface.
For CADian Classic & CADian Pro 2024 (and older) Users :
2/ Download & Extract the attached file :
  • CADLisp_Pro2024&Classic_Manual Install
3/ Copy all extracted files into [C:\cadian] folder.
4/ Launch CADian Pro or Classic
5/ Type [ap] (Appload) in the command line and press Enter
6/ Click [Contents] in Startup Suite (marked in Red in image below)
  • Startup Suite popup should appear
  • Click [Add]
  • Navigate [C:\cadian] and [LSP _ALL.ELF] file
    • [c:\cadian\LSP_ALL.ELF]
  • Exit the popup and Application window by pressing [Close] then [Close] again
7/ Utility programs will load automatically, adding a new menu to your interface.
