nbd01
problems with Cadian 2010 patch 5.10
I have just installed CADian 2010 from Cadian 2008i. I am experiencing the following problems with Patch 5.10 1. Text will not justify left, text is displaying vertically (down page) not horizontally (across page). Every time that I adjust it it will go back to vertical. Have checked the same drawing in AutoCAD 2011 & it displays correctly! Problem is in CADian. 2. Block updating, the same block will not update to new saved block. When saving the program asked if referenced blocks in drawing should be updated? I answer yes, however it does not update same referenced blocks in the drawing. I have ran the same drawing in AutoCAD 2011 & it works fine. Please advise!
