krho
Scripts from start
Hi, once again I temporarily worked around the issue with spaces in the searchpath(see my previous questions) by changing the name of the printer to not include spaces... Will this be fixed for CADian 2012? Now I want to run this script on startup of CADian, I do so by making a shortcut to icad.exe, after that I go to the "Shortcut" tab in properties, in the field "Target" I enter, for example: "C:\Program Files\CADian2011\icad.exe" /b "C:\Program Files\CADian2011\scripts\MyScript.scr" The "/b"-switch specifies which script to run immediately when CADian starts, right? I read so in a manual for Intellicad which is what CADian is built on, correct? But I get a message telling me that my script is an invalid file extension, does CADian support this function at all? If not, will it be supported in the future? Best regards Kristoffer
