RE : About the effect method
Is there any way to make a solid line appear as a bleed effect when selecting an object in CADian? And is there any way to give it a highlight effect when the object is not selected but just hovered over?
Thank you for your asking.
Please follow method below:
Solid line effect Set to on after running the command: SELECTIONEFFECT. Run the command: GSDEVICEMODE and set it to 3. Emphasis effect This can be fixed with the command: SELECTIONPREVIEW 1.
Thank you:)
