RE : RE :About superpurge
Cadian has a superpurge feature, how does this compare to the existing purge feature?
If the command you asked about is superpurge, then run the audit , EraseEmptyEnt2 , utilpurgeall , Purge commands to fix the detected errors. - Remove ghost objects. - Remove unused scale lists. - Executes Purge. - It is a function that can execute the functions required for drawing organization with a single click.
