Cadian has a superpurge feature, how does this compare to the existing purge feature?
---------------------------๐ Answer--------------------------- If the command you asked about is superpurge, then run the audit , EraseEmptyEnt2 , utilpurgeall , Purge commands to fix the detected errors.
- Remove ghost objects.
- Remove unused scale lists.
- Executes Purge.
- It is a function that can execute the functions required for drawing organization with a single click.
