RE : RE :I'd like to inquire about ClAYER functionality.
In the previous version of AutoCAD, I could change the layer by simply typing the "layer name" and pressing Enter in the command prompt. However, in CADian, it seems I need to enter "CLAYER," then press Enter, and finally input the "layer name" to make changes. Is there any other method to achieve this?
Please try using the "_RENAME" command to make the changes. The "CLAYER" command is a variable value.
