pdf File Size
I've switched from using AutoCAD to CADian. Currently, when I convert drawing files to PDF using CADian,
I noticed that the file size is significantly larger compared to AutoCAD.
ex) AutoCAD = 15,521KB, CADian = 78,265KB
Could you explain the reason for such a difference?
Hello, this is CADian.
When converting to a pdf file, differences in file sizes can occur depending on resolution and paper size settings.
Please try converting in CADian using the same settings you applied in AutoCAD.
Print/Plotting
pdf File Size
coolbreeze
2023.09.11
Print/Plotting
pdf File Size
2023.09.11
