RE :How to convert multiple drawing into a single PDF file?
Is there a function to merge 50 individual drawings into a single PDF when they are in separate files, or do I need to use a different program to merge them all together?
---------------------------๐ Answer--------------------------- Hi, Thank you for asking.
After running the 'mplot' command, click on the list on the top left corner.
Then, click 'Add Files' to add the drawings you want. After that, set the printer name to 'dwg to pdf', and on the top right, check all three options: 'Merge to PDF,' 'Merge by Drawing,' and 'Delete Merged Files.'
