RE : RE :Font rendering problems
The issue my experiencing with font rendering problems when opening AutoCAD files in CADian and working on PDF is a common problem in computer-aided design software. Is there a solution for these problems?
The command for addressing font distortion issues is to execute "TEXTQLTY" and change the value to 100, then please check.
If the issue does not improve even after executing this command, please contact the our technical support team.
