RE : RE :Error message when running CADian.
When the program is run, a capture message appears, and you need to click OK for the program to run. Is there a solution to this issue?
Thank you for asking and sorry for the inconvenience.
I will provide you with a solution to the issue you mentioned. Control Panel > Clock and Region > Administrative options > Change system locale > At the bottom, uncheck "Beta: Use Unicode UTF-8 for worldwide language support." If you encounter any further problems after using this method, please feel free to contact us.
