RE : RE :About KNURL Command
Please explain about KNURL command and how to prevent it from running
The "K=KNURL" command can be considered as an alias for Hatch. It is a command that is also used in AutoCAD. To change it, follow these steps: 1. Click on "Express" and go to the "Tool" menu. 2. In the "Tool" menu, click on the "Alias Editor. In the "Alias Editor," click on the "File" tab. 3. Click on "Export" to save the current PGP (Program Parameters) file to a text file. 4. Open the PGP file in Notepad. 5. Look for "K=KNURL" and change the "KNURL" command to something else. Save the file. 6. Go back to the Alias Editor window. 7. Click on "Import" to import the modified PGP file. 8. Click "Apply" to confirm the changes.
