RE : RE :How to extend objeck in CADian?
When you execute the "xc" command and want to cut a block, click on the option to create a new boundary. After clicking the rectangle, draw the desired range. The block will be cut, and you can see only the desired size. After selecting the cut block, you can change it to the desired shape by specifying blue points, just like in the video. If the blue points are not being detected, please contact us.
