RE : RE :I don't see a cursor that helps centering
Hello, when using Windows to set the print area, I don't see a cursor helps centering, making it difficult to accurately set the print area. Could you please clarify what might be the issue?
You can perform the requested task by executing the OSNAP command, checking the endpoint, and then pressing F3 to toggle it on and off after completion.
