RE : RE :How to use again CTRL C, CTRL V, and DELETE buttons again when using CADian?
I used to frequently use CTRL C, CTRL V, and DELETE buttons again when using CADian. However, at some point, it stopped working. Is there any way to solve this problem?
If you type 'OP' in the command prompt, the following screen will appear. Go to the 'Selection' tab and check the 'Noun/Verb Selection' option under the Selection Mode.
This should resolve the issue.
If the issue persists, please feel free to contact us at any time.
