Contact Us
Contact Us
RE :I want to output all objects with the same line thickness
Is if possible to output all objects with the same line thickness if each objects has a different line thickness set individually?
After the "plot" command, if you turn off the "print entity line weight" option in the window as follows and then output it, all lines will appear thin.
If this method doesn't work for you, please feel free to ask again anytime!
H/W
I want to output all objects with the same line thickne..
brightstar6
2024.01.29
H/W
RE :I want to output all objects with the same line thi..
2024.01.29
