RE : RE :Issue of the mouse wheel movement
After installation CADian, the mouse wheel movement was working, but now it's not working during drawing tasks. Is there a solution?
In this case, it seems like you'll need to reset to the default settings. If you've modified any shortcuts before executing this commands, you should go to the top menu, navigate to 'exporee> tools > command Alias Editor', and export the file to a different folder as a back up. Then, reset to the default settings, and import the file again.
