RE : RE :How to check the dimension?
I received a STEP file, but I'm not sure how to check the dimensions. I also need to know how to open it since it's not opening.
Please try opening the step file below:
1. Type "import" in the command prompt to execute the import function. 2. Select "File Format" > "STEP" and choose the STEP file. 3. When the balloon help appears in the lower right corner, click on the file name. 4. Execute "zoom > e" to display the objects on the drawing. To input dimensions, simply input them onto the existing solid objects in the same manner as you would with regular solid objects.
