RE : RE :When using an infinite line, it is only generated to the size of the screen.
In the above, there is a one-sided infinite line on top and a two-sided infinite line on the bottom, but only the size of the initially created screen is generated, and when zooming out, the infinite line is not visible while maintaining its original size attributes. Even after changing the zoom and regenerating, it remains exactly the same.
This symptom can be resolved by entering regenmodeglobal in the command window, then pressing 2 and pressing Enter. When the zoom is changed, the infinite line will be displayed immediately. The regenmodeglobal is initially set to 0 by default during installation, so you can change it and use it. If the object is complex, setting regenmodeglobal to 0 and using it will eliminate the symptom of waiting during drawing due to automatic regeneration. There are pros and cons depending on the user's characteristics.
