RE : RE :Issue of Image
When I load an image in CADian, after zooming in and then zooming out, only the portion that was zoomed in is visible, and the rest requires regeneration to be seen. Additionally, when zooming in and out, the image resolution appears to be degraded, but regeneration fixes it. Is this a setting issue or inherent in CADian? If there's a solution, please explain.
Please check a few system variables below: In the command line, type regenauto, press Enter, type on, then Enter. In the command line, type regenmode, press Enter, type on, then Enter. In the command line, type regenmodeglobal, press Enter, type 2, then Enter. With these settings, regeneration should occur automatically when needed.
