RE :How to change all z values to 0 in the CADian 2020 version?
It seems like the 'zero' command doesn't work in the CADian 2020 version. Is there any way to change all z values to 0 in the 2020 version?
The 'zero' command does exist in CADian 2020 Pro. If you are using CADian 2020 Classic, you can select all the desired objects, open the properties window (invoked by ctrl+1), and enter '0' for the start z and end z values.
greenturtle
2024.04.08
RE :How to change all z values to 0 in the CADian 2020 versi..
2024.04.08
