Dear Sir, To produce PDF file using virtual printer PDF driver in CADian. It""s possible to set the paper, adjust the margin and set the width of line. [ Intstallation guide and notes ] 1. Please downlaod the attached doPDF. - Attachment : dopdf-7.zip 2. Click START at Windows > Control Panel > Printer > doPDF > Properties > Printing Preferences,, > Set the Paper size & the Drawing Orientation(Landscape/Portrait) 3. Run your CADian and set the Printer as doPDF. 4. Try to set printoptions as the same way to print in real. 5. When the PDF-file-save-window is up, click [ Browse ] and select the folder want to save. 6. The output file will be opened automatically with Adobe Acrobat Reader. Thanks, CADian Soft
