RE : RE :Is there a way to add hatches similar to AutoCAD in CADian?
I used to use AutoCAD, but now I'm using CADian. Is there a way to add hatches similar to AutoCAD in CADian?
When you use 'HATCH' command, the hatch and gradient window will pop up. In that window, you can configure pattern types, colors, transparency and gradient setting just like in AutoCAD.
