RE : RE :Originally, was the cfm cross-section feature not available in CADian?
I've been using AutoCAD and wanted to try CADian, so I downloaded the trial version and started using it, but I can't find the cfm cross-section extraction feature. Is it originally not available?
You can directly input "cfm" in the command line, or select "Cross Section Extraction" under Menu: Dream > Civil > Cross > Topography in order to activate that feature.
