---------------------------โ Question---------------------------
I am a user of version CADian 2023.The CADian cs team advised me to install CADian version 2024 because the issues with layer filters sorting and 3D polylines have been resolved, but now I've encountered a new problem. When I zoom in, the fonts get corrupted. What should I do?
---------------------------๐ Answer---------------------------
Thank you for asking .
In 2024, there is a system variable called regenmodeglobal, which is default to 0.
If you type regenmodeglobal in the command line, then press Enter, followed by 2, and then Enter again, the issue should be resolved.
This setting is in place to prevent automatic regeneration of complex drawings, which could cause delays.
If this setting is inconvenient for you, you can change it as described above.
