Microsoft Print to PDF causing the software package to crash?
1. CADian version in use :2004
2. Applications in use : CADian, Microsoft Print to PDF
3. Content : I am supporting a client using CADian, yesterday he reached out to me because when he tried to use Microsoft Print to PDF to generate PDF documents from CADian, it is causing the program to hang. Looking at the print queue, it appears that the print driver reaches the spooling stage and then stops.
We have tested Microsoft Print to PDF using other software and the print drivers works in programs other than CADian. We have also used the CutePDF print driver in CADian to successfully generate PDF file.
There appears to be a conflict between CADian and the current Microsoft Print to PDF driver in this version of CADian.
